Sparkfun LiPoly Battery Charger
I have an unopened sparkfun LiPOLY BATTERY CHARGER from about 10 years go. I believe the SKU is/was 187496 or SF-RTL-09876.
Looking for any documentaton such as techincal description and hookup guide.
Thanks in advance!
Garry
If you have this one its guide is here
Thanks but no, I have an older version:
That’n must be even older! The one I linked is from ~12 years ago
The good news is that the one you have and the one above are nearly identical in terms of function…your version has fewer components populated but the basic wiring scheme and jumper adjustments work the same
Compared with the newer one
yours doesn’t have the barrel jack or the charge current external resistor but the rest of that guide should be applicable
Just a side note: I would not try to charge the lipo in that package (use a newer one, ensure the polarity matches…after a decade or more they can get a bit sketchy
Are there more parts obfuscated or does the package contain just board & battery only?
