Hi there,
If I’m to use pull-up resistors in both sides (3.3v and 5v sides) of the I2C line, I should consider a level shifting and or else disable Atmel328p input pull-ups of I2C lines and use without pull-up resistors and level shifting?
Are the pull-up resistors enabled by default for I2C ports of Atmel328p?
As a best design practice, should I always use pull-up resistors with a level shifting in I2C lines?
