The MMC5983MA has an internal function that allows to calculate the three offsets automatically, although this may not be sufficient to obtain accurate heading measurements. See the Sparkfun library example 7 (I2C sensor offset).
Thank you @jremington. I have read the cavepearl project, I think I will get one of the sensors that has been used. Once I have better understanding I’ll try my MMC5983MA again.
In any case, it would be helpful for others if you would run the library example “I2C sensor offset” and tell us what offsets you get. One or more of them is likely to be very different than the value assumed by the compass application.
You will have to add a bit of code to the example, to print out those offsets.
The unmodified example 7 output does not show the offsets. Please try this slightly modified code and post the offsets that the program calculates and prints.
Removing the bridge offset from the MMC5983MA
By: Paul Clark
SparkFun Electronics
Date: February 9th, 2023
License: SparkFun code, firmware, and software is released under the MIT License(http://opensource.org/licenses/MIT).
Feel like supporting our work? Buy a board from SparkFun!
https://www.sparkfun.com/products/19034
This example shows how to remove the sensor (bridge) offset.
Press a key (send any character) to perform the set-reset and update the offset.
Hardware Connections:
Plug a Qwiic cable into the sensor and a RedBoard
If you don't have a platform with a Qwiic connection use the SparkFun Qwiic Breadboard Jumper
(https://www.sparkfun.com/products/17912) Open the serial monitor at 115200 baud to see the output
From the datasheet:
USING SET AND RESET TO REMOVE BRIDGE OFFSET
The integrated SET and RESET functions of the MMC5893VA enables the user to remove the error
associated with bridge Offset change as a function of temperature, thereby enabling more precise heading
measurements over a wider temperature than competitive technologies. The SET and RESET
functions effectively alternately flip the magnetic sensing polarity of the sensing elements of the device.
1) The most accurate magnetic field measurements can be obtained by using the protocol described
as follows: Perform SET. This sets the internal magnetization of the sensing resistors in the
direction of the SET field.
2) Perform MEASUREMENT. This measurement will contain not only the sensors response to the
external magnetic field, H, but also the Offset; in other words,
Output1 = +H + Offset.
3) Perform RESET. This resets the internal magnetization of the sensing resistors in the
direction of the RESET field, which is opposite to the SET field (180o opposed).
4) Perform MEASUREMENT. This measurement will contain both the sensors response to the
external field and also the Offset. In other words,
Output2 = -H + Offset.
5) Finally, calculate H by subtracting the two measurements and dividing by 2. This procedure
effectively eliminates the Offset from the measurement and therefore any changes in the
Offset over temperature.
Note: To calculate and store the offset; add the two measurements and divide by 2. This calculated offset
value can be subtracted from subsequent measurements to obtain H directly from each measurement.
#include <Wire.h>
#include <SparkFun_MMC5983MA_Arduino_Library.h> //Click here to get the library: http://librarymanager/All#SparkFun_MMC5983MA
SFE_MMC5983MA myMag;
void setup()
// Most Serial prints have been commented out - to allow the data to be plotted nicely using Tools \ Serial Plotter
//Serial.println("MMC5983MA Example");
Wire.begin();
if (myMag.begin() == false)
Serial.println("MMC5983MA did not respond - check your wiring. Freezing.");
while (true)
myMag.softReset();
//Serial.println("MMC5983MA connected");
//Serial.println("Press a key (send any character) to perform the set-reset and update the offset.");
while (Serial.available())
Serial.read(); // Empty the Serial RX buffer
void loop()
// The magnetic field values are 18-bit unsigned. The zero (mid) point is 2^17 (131072).
// Use static variables to hold the offset. Set to 131072 initially.
static uint32_t offsetX = 131072;
static uint32_t offsetY = 131072;
static uint32_t offsetZ = 131072;
// Has the user pressed a key?
if (Serial.available())
updateOffset(&offsetX, &offsetY, &offsetZ); // Update the offsets
uint32_t currentX = 0;
uint32_t currentY = 0;
uint32_t currentZ = 0;
// This reads the X, Y and Z channels simultaneously
myMag.getMeasurementXYZ(¤tX, ¤tY, ¤tZ);
// The zero (mid) point should be 2^17 (131072).
// Here we subtract the offset, then normalize each field to +/- 1.0,
// then multiply by 8 to convert to Gauss
double normalizedX = (double)currentX - (double)offsetX; // Convert to double _before_ subtracting
normalizedX /= 131072.0;
normalizedX *= 8.0;
double normalizedY = (double)currentY - (double)offsetY; // Convert to double _before_ subtracting
normalizedY /= 131072.0;
normalizedY *= 8.0;
double normalizedZ = (double)currentZ - (double)offsetZ; // Convert to double _before_ subtracting
normalizedZ /= 131072.0;
normalizedZ *= 8.0;
// Print the three channels with commas in between so the Serial Plotter can plot them
Serial.print(normalizedX, 5); // Print with 5 decimal places
Serial.print(",");
Serial.print(normalizedY, 5);
Serial.print(",");
Serial.println(normalizedZ, 5);
bool updateOffset(uint32_t *offsetX, uint32_t *offsetY, uint32_t *offsetZ) // Update the offsets
bool success = true; // Use AND (&=) to record if any one command fails
success &= myMag.performSetOperation(); // Perform the SET operation
uint32_t setX = 131072;
uint32_t setY = 131072;
uint32_t setZ = 131072;
success &= myMag.getMeasurementXYZ(&setX, &setY, &setZ); // Read all three channels
success &= myMag.getMeasurementXYZ(&setX, &setY, &setZ); // Do it twice - just in case there is noise on the first
success &= myMag.performResetOperation(); // Perform the RESET operation
uint32_t resetX = 131072;
uint32_t resetY = 131072;
uint32_t resetZ = 131072;
success &= myMag.getMeasurementXYZ(&resetX, &resetY, &resetZ); // Read all three channels
success &= myMag.getMeasurementXYZ(&resetX, &resetY, &resetZ); // Do it twice - just in case there is noise on the first
// Calculate the offset - as per the datasheet.
// The measurements are 18-bit so it's OK to add them directly.
if (success)
*offsetX = (setX + resetX) / 2;
*offsetY = (setY + resetY) / 2;
*offsetZ = (setZ + resetZ) / 2;
Serial.print("Offsets: ")
Serial.print((setX + resetX) / 2);
Serial.print(", ");
Serial.print((setY + resetY) / 2);
Serial.print(", ");
Serial.print((setZ + resetZ) / 2);
Serial.println();
return success;
As I suspected, the calculated offsets are VERY different than what the compass program assumes (especially in Y and Z), which are as follows. That alone is enough to completely invalidate the assumptions made in the compass program.
“Normalizing” converts an arbitrary vector into a unit vector, with length=1. Doing so is required for some types of vector operations, such as calculating angles.
Mapping or scaling would be less confusing. The other issue is that in general, each axis needs a separate scale factor to make them consistent, and the present example code might suggest to some that the offset value accomplishes this as well.
Code to correct magnetometer data, in its simplest form, requires six parameters, for example something like this:
I have been following your conversation I understand it all now. Thank you for the new documented examples.
I am now very familiar with my little magnetometer .
I have tried Compass example as is i.e. dividing by 131072, and I tried it with the mag=sqrt(xx + yy) adjusted X= x/mag, adjusted Y=y/mag. As the numbers are pretty much the same and both are constants, the outcomes are not dissimilar. I am still wading through all the documentation from Sailboat instruments and the cave pearl project about calibration.
