SparkFun OpenLog Artemis -> looking a similar design but with nRF52840
I am checking if there is a design of the SparkFun OpenLog Artemis but with nRF52840.
The SparkFun OpenLog Artemis has all the needed components (charging, SD, card and IMU + extension for extra IMU) but I am looking for an nRF52840 version.
Unfortunately there isn’t a version that’s based on the nRF52840, but you could almost have the same thing by combining the [nRF52840 processor board with the [MicroMod Machine Learning Carrier Board. You’d just need to connect an external battery charger board and voltage regulator.](SparkFun MicroMod Machine Learning Carrier Board - DEV-16400 - SparkFun Electronics)](https://www.sparkfun.com/products/16984)
Thanks.
Currently, I am developing the firmware on the MicroMod nRF52840 processor board in combi with the ML carrier and the IMU.
However, the goal is to come to a smaller size solution one PCB solution.
The SparkFun OpenLog Artemis board size is just what I need, but using an nRF52840.
It seems I need to design a new carrier board…
