Hi
Can the ‘UP’ & ‘DOWN’ orientation be swapped simply in the code?
Many thanks in advance
Hi
The python code https://github.com/sparkfun/Qwiic_Joyst … tick.py#L1 modification would be:
import smbus
import time
bus = smbus.SMBus(1)
addr = 0x20
def main():
global bus_data, X, Y
while True:
qwiicjoystick()
def qwiicjoystick():
try:
bus_data = bus.read_i2c_block_data(addr, 0x03, 5)
except Exception as e:
print(e)
X = (bus_data[0] << 8 | bus_data[1]) >> 6
Y = ((bus_data[2] << 8 | bus_data[3]) >> 6) * -1 # Reverse the sign for the Y-axis values
print(X, Y, " Button = ", bus_data[4])
time.sleep(0.05)
if name == ‘main’:
main()
That should work…all it does it multiply Y*-1 to invert the sign of its value
