I wanted to use the SEN-16476 MicroPressure to detect the water level inside my freshwater tank. For that I connected a tube to the MPR and put the tube in the tank. This worked well, but after a day I pulled out the tube, but the MPR Sensor did not showed the correct values. After some investigations, I found out that it took him around 1 hour to show the correct environmental pressure again.
Is the MPR only usable for short term pressure? If so, please add that to the documentation, as this prevents me from using it in this way. If not, please help me fixing this issue!
Martin
