SparkFun Qwiic MicroPressure
Is there a way to obtain the temperature reading as well as the pressure from the SparkFun Qwiic MicroPressure breakout board? The example code does not include anything related to temperature. Thanks.
No, it’s a pressure sensor, not a temperature sensor, you’d need a separate temperature sensor on your qwiic bus to sense temperature.
YellowDog thanks for the reply. It appeared the datasheet indicated that the pressure measurement is temperature compensated which I assume means it would need to measure temp as well. A similar board by others also produces temp as well as presure.
