Hey, sorry for the late reply. Yea the acctual basement flooding is now a lawsuit thing, but i need my THING to log some nice data just so i can prepare. Higher Hum and Temp could notify me of how much the soil absorbs water around and under my basement.
Aanyways, the packadge from SparkFun came today. No idea why the shipping went so slow. I have two Things now.
So far just testing:
Hookup Guide, loaded Phant and the Thing libraries.
Fun stops at Upload of the Hookup Guide`s Test (https://learn.sparkfun.com/tutorials/es … g-to-phant)
After loading it seems Arduino recognizes the board to reside on COM9, i cannot find the unit in my Windows Device Manager either. the board is in OFF mode, as i read a warning about uploading in ON mode.
Anyone know how to troubleshoot my issue? Board is directly connected to a usb port for power+data.
Arduino:1.6.5 (Windows 8.1), Kort"SparkFun ESP8266 Thing, 80 MHz, 115200"
Build options changed, rebuilding all
Using library ESP8266WiFi in folder: C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi
Using library Phant in folder: C:\Users\UPC\Documents\Arduino\libraries\Phant
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src -IC:\Users\UPC\Documents\Arduino\libraries\Phant\src C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266_Phant.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266_Phant.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src -IC:\Users\UPC\Documents\Arduino\libraries\Phant\src C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266WiFi\ESP8266WiFi.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src -IC:\Users\UPC\Documents\Arduino\libraries\Phant\src C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src -IC:\Users\UPC\Documents\Arduino\libraries\Phant\src C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src\WiFiClient.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266WiFi\WiFiClient.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src -IC:\Users\UPC\Documents\Arduino\libraries\Phant\src C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src\WiFiServer.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266WiFi\WiFiServer.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src -IC:\Users\UPC\Documents\Arduino\libraries\Phant\src C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src\WiFiUdp.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266WiFi\WiFiUdp.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src -IC:\Users\UPC\Documents\Arduino\libraries\Phant\src C:\Users\UPC\Documents\Arduino\libraries\Phant\src\Phant.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Phant\Phant.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -g -x assembler-with-cpp -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\cont.S -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\cont.S.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\cont_util.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\cont_util.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_eboot_command.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_eboot_command.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_flash_utils.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_flash_utils.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_i2s.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_i2s.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_noniso.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_noniso.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_phy.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_phy.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_postmortem.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_postmortem.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_si2c.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_si2c.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_timer.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_timer.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_wiring.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_wiring_analog.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring_analog.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_wiring_digital.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring_digital.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_wiring_pulse.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring_pulse.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_wiring_pwm.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring_pwm.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_wiring_shift.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring_shift.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\libc_replacements.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\libc_replacements.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\spiffs\spiffs_cache.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\spiffs_cache.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\spiffs\spiffs_check.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\spiffs_check.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\spiffs\spiffs_gc.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\spiffs_gc.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\spiffs\spiffs_hydrogen.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\spiffs_hydrogen.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\spiffs\spiffs_nucleus.c -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\spiffs_nucleus.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\abi.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\abi.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\core_esp8266_main.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_main.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\debug.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\debug.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\Esp.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Esp.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\HardwareSerial.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\HardwareSerial.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\IPAddress.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\IPAddress.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\pgmspace.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\pgmspace.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\Print.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Print.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\Stream.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Stream.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\Tone.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Tone.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\Updater.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Updater.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\WMath.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\WMath.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_THING -DARDUINO_ARCH_ESP8266 -DESP8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266 -IC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\variants\thing C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\cores\esp8266\WString.cpp -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\WString.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\cont.S.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\cont_util.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_eboot_command.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_flash_utils.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_i2s.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_noniso.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_phy.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_postmortem.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_si2c.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_timer.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring_analog.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring_digital.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring_pulse.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring_pwm.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_wiring_shift.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\libc_replacements.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\spiffs_cache.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\spiffs_check.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\spiffs_gc.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\spiffs_hydrogen.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\spiffs_nucleus.c.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\abi.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\core_esp8266_main.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\debug.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Esp.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\HardwareSerial.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\IPAddress.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\pgmspace.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Print.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Stream.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Tone.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Updater.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\WMath.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\WString.cpp.o
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -g -Os -nostdlib -Wl,–no-check-sections -u call_user_start -Wl,-static -LC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//lib -LC:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//ld -Teagle.flash.512k.ld -Wl,-wrap,system_restart_local -Wl,-wrap,register_chipv6_phy -o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/ESP8266_Phant.cpp.elf -Wl,–start-group C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266_Phant.cpp.o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266WiFi\ESP8266WiFi.cpp.o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266WiFi\ESP8266WiFiMulti.cpp.o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266WiFi\WiFiClient.cpp.o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266WiFi\WiFiServer.cpp.o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\ESP8266WiFi\WiFiUdp.cpp.o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp\Phant\Phant.cpp.o C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/core.a -lm -lgcc -lhal -lphy -lnet80211 -llwip -lwpa -lmain -lpp -lsmartconfig -lwps -lcrypto -Wl,–end-group -LC:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\esptool\0.4.5/esptool.exe -eo C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/bootloaders/eboot/eboot.elf -bo C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/ESP8266_Phant.cpp.bin -bm qio -bf 40 -bz 512K -bs .text -bp 4096 -ec -eo C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/ESP8266_Phant.cpp.elf -bs .irom0.text -bs .text -bs .data -bs .rodata -bc -ec
Sketch uses 297 468 bytes (68%) of program storage space. Maximum is 434 160 bytes.
Global variables use 48 168 bytes (58%) of dynamic memory, leaving 33 752 bytes for local variables. Maximum is 81 920 bytes.
C:\Users\UPC\AppData\Roaming\Arduino15\packages\esp8266\tools\esptool\0.4.5/esptool.exe -vv -cd ck -cb 115200 -cp COM9 -ca 0x00000 -cf C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/ESP8266_Phant.cpp.bin
esptool v0.4.5 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to ck
setting baudrate from 115200 to 115200
setting port from COM1 to COM9
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
stat C:\Users\UPC\AppData\Local\Temp\build1528979720008253908.tmp/ESP8266_Phant.cpp.bin success
error: Failed to open COM9
error: espcomm_open failed
Fant ikke boards.txt i C:\Program Files (x86)\Arduino\hardware\hardware\YunShield. Er filen pre-1.5?
WARNING: Error loading hardware folder C:\Program Files (x86)\Arduino\hardware\hardware
No valid hardware definitions found in folder hardware.
Fant ikke boards.txt i C:\Users\UPC\Documents\Arduino\hardware\hardware\YunShield. Er filen pre-1.5?
WARNING: Error loading hardware folder C:\Users\UPC\Documents\Arduino\hardware\hardware
Board at COM9 is not available
