Is there mapping available for this display to create raw images? I looked but didn’t see it available in the document tab or through other sources. Adafruit’s 4 number 14 segment display documentation seems to differ or my hex is bad. Thanks.
https://live.staticflickr.com/65535/510 … 200b_m.jpg
Using this example I found the mapping to be:
00 L M N K J G2 H G1 F E D C B A
Not sure if this is what you’re after or not, but the link below will take you to a data sheet for the display. That might be helpful!
