Hi all, I well played with dc motors, now i want to try ac motors,
I googled and found http://playground.arduino.cc/Main/ACPhaseControl
actually the topic is not only related to arduino we can use any MCU, but i always first try with arduino then extend my work to others ---- AVR, PIC, 8051, Raspberry pi, FPGA/CPLD…
OK the above tut uses the following components,
for zero crossing detection H11AA1
for triac control MOC3052
triac some other
but unfortunately i could not find the main components viz. H11AA1, MOC3052, and the triac on some local market.
so i decided to use substitutes and come up with following,
H11AA1 substitute with MCT2E and bridge rectifier, transformer
MOC3052 substitute with MOC3021
Triac i use BT 136
I planned the following schematic pls see attached images :
zero Crossing Detector :
http://i1374.photobucket.com/albums/ag4 … hubmr4.pngtriac switch :
http://i1374.photobucket.com/albums/ag4 … twixel.pngnow before ordering the components i need your advice as i know i am going to play with AC mains, pls first check the circuit ---- is everything OK ?
if any thing wrong etc pls tell me.
i selected R1 to be 1k in zeroCrossDetector is it OK and safe for the MCT2E ?
pls reply soon, so that i can order the parts and start further…
thanks in advance
