For which constellations (GPS, GLONASS, GALILEO, BEIDOU) did you collect RTK points?
I’m not at my work computer, so I don’t have access to the metadata at the moment.
But I’m fairly confident those particular results are from the SparkFun Torch (UM980) with a good bit of tweaking in the configuration.
I do not turn off any constellations, but I do keep SBAS off for all devices I test or use.
The PostCard (LG290P) can get even tighter with a good antenna (because of the antenna) ![]()
The Same is true for your F9P, in my experience.
I’ve been equally impressed with all (3) chipsets. Each one has it’s individual quirks, but all 3 are fabulous when tweaked and paired with a great correction source.
