Stepper drive
Please can someone give me a clue how to run a stepper motor with an Arduino the wiring is easy but the code makes no sense at all and all the tutorials don’t explain how the code flows. I just want a bit of code to run the stepper x amount of steps forward when a pin is goes high. :doh:
If you post the code that’s confusing you, perhaps someone will explain it.
That’s what I am after just a bit of code I can experiment with then I might start to understand the code in the library works ok but not what I am after
Then, maybe, just maybe, you could write a bit of code yourself. And when that doesn’t work, the masses can ASSIST you in figuring out how to make it work the way YOU want it to work.
Spoon Feeding?
Ya, probably not…
inkwizitiv:
Please can someone give me a clue how to run a stepper motor with an Arduino…
Are you asking because you have a setup now that doesn't work? If so, what hardware do you have and what library are you using?
