I have a question about a stepper motor I want to use in a project using an Arduino and the BigEasydriver. I am looking for a stepper motor that is able to lift and hold a TV weighing in at 12-14 pounds. Can anyone help me out choosing a motor with these requirements?
Is there any reason you’re using a stepper ? Nothing wrong with that but I’m not sure there’s any advantage either. One thing I will say is I don’t think you want to rely on the motor, under power, to hold the TV up and in place. I’d recommend some sort of ratchet mechanism or better yet a worm drive.
The TV needs to go up about 20inches, it doesn’t need to go fast. I was looking at a stepper motor because it was less expensive than linear actuators.
Linear actuators also don’t go up that high apparently. The thing I really want to know is is a stepper motor up to the job of lifting that kind of weight. If not I shouldn’t waste time looking into it obviously.
So would 10 secs be a reasonable deployment time ? And to re-ask waltr’s question … what’s your thinking on the mechanics of this ? My first thought is to use/make some kind of electric scissor jack arrangement.
Mee_n_Mac:
For $90, Pololu sells a 12 volt linear actuator that will lift 110 pounds 12 inches. Given a lever arrangement like the scissor jack above, a lighter object could be raised much higher. A couple of switches are all that would be required to control it. See http://www.pololu.com/catalog/product/2312
Any stepper motor will require a gearbox to lift your TV. Adding in the requirements for a power supply, motor driver and controller, it is hard to imagine that any stepper arrangement that you could come up with would be much cheaper than the linear actuator.
