Hi Guys,
I’ve just downloaded openocd to use with the olimex wiggler on the str710.
I’m using open openocd-2006re115-setup-rc01 on winxp sp2.
I cant seem to get it to write the flash and it doesn’t seem to want to call a target script from the cfg file, heres my cfg (i know i probably don’t need as big a delays as i’ve got in it but i wouldn’t have thought that a problem)
telnet_port 4444
gdb_port 3333
#interface
interface parport
parport_port 0x378
parport_cable wiggler
jtag_speed 0
jtag_nsrst_delay 100
jtag_ntrst_delay 100
reset_config srst_only
jtag_device 4 0x1 0xf 0xe
daemon_startup reset
target arm7tdmi little run_and_halt 0 arm7tdmi
run_and_halt_time 0 1000
working_area 0 0x2000C000 0x4000 nobackup
#flash bank <chip_width> <bus_width>
flash bank str7x 0x40000000 0x00040000 0 0 STR71x 0
wait_halt
poll
flash banks
flash info 0
flash probe 0
flash erase_check 0
flash erase 0 0 7
flash write 0 LCD.img 0
#target_script 0 reset Myscript.script
It doesn’t seem to erase the flash and program it (it says command not found) and if i uncomment my script line it doesn’t seem to run it.
Log file:
Info: configuration.c:50 configuration_output_handler(): Command wait_halt not found
Info: configuration.c:50 configuration_output_handler(): Command poll not found
Info: configuration.c:50 configuration_output_handler(): Command banks not found
Info: configuration.c:50 configuration_output_handler(): Command info not found
Info: configuration.c:50 configuration_output_handler(): Command probe not found
Info: configuration.c:50 configuration_output_handler(): Command erase_check not found
Info: configuration.c:50 configuration_output_handler(): Command erase not found
Info: configuration.c:50 configuration_output_handler(): Command write not found
Debug: jtag.c:1210 jtag_init():
Debug: parport.c:373 parport_init(): requesting privileges for parallel port 0x378…
Debug: parport.c:383 parport_init(): …privileges granted
Debug: parport.c:210 parport_reset(): trst: 0, srst: 0
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 1
Debug: jtag.c:1096 jtag_reset_callback():
Debug: openocd.c:100 main(): jtag init complete
Debug: arm7_9_common.c:656 arm7_9_assert_reset(): target->state: unknown
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 0
Debug: parport.c:210 parport_reset(): trst: 0, srst: 1
Debug: arm7_9_common.c:722 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 2
Debug: openocd.c:104 main(): target init complete
Debug: openocd.c:108 main(): flash init complete
Debug: gdb_server.c:1347 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug: embeddedice.c:157 embeddedice_read_reg_w_check(): 1
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 3
Debug: arm7_9_common.c:838 arm7_9_halt(): target->state: running
Debug: embeddedice.c:253 embeddedice_write_reg(): 9: 0xffffffff
Debug: embeddedice.c:253 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:253 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:253 embeddedice_write_reg(): 13: 0x000000f7
Debug: arm7_9_common.c:620 arm7_9_poll(): DBGACK set, dbg_state->value: 0x9
Debug: embeddedice.c:253 embeddedice_write_reg(): 0: 0x00000005
Debug: embeddedice.c:253 embeddedice_write_reg(): 12: 0x00000000
Debug: arm7_9_common.c:944 arm7_9_debug_entry(): target entered debug from ARM state
Debug: arm7_9_common.c:976 arm7_9_debug_entry(): target entered debug state in User mode
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r0: 0x00002710
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r1: 0x00001ba2
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r2: 0x00000935
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r3: 0x00002709
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r4: 0x0c908e04
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r5: 0x00508281
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r6: 0x00b3dc24
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r7: 0x90113403
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r8: 0x290c44c6
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r9: 0x00098848
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r10: 0x200001e4
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r11: 0x200001ec
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r12: 0x200001f0
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r13: 0x200001dc
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r14: 0x00000750
Debug: arm7_9_common.c:1005 arm7_9_debug_entry(): r15: 0x00000d40
Debug: arm7_9_common.c:1011 arm7_9_debug_entry(): entered debug state at PC 0xd40
Debug: target.c:442 target_call_event_callbacks(): target event 0
Any help greatfully appreciated
Giles
