Thanks, your patch and updating to revision 209 fix the working area problem. However, there is still a problem with flash loads when a working area is not specified. The following command fails with a packet error:
#Load flash
monitor flash write 0 main.bin 0
This is what gdb outputs:
Ignoring packet error, continuing...
/cygdrive/c/Documents and Settings/dave_e/My Documents/ECLIPSE/worspace/OM200 OCB/gdbinit:85: Error in sourced command file:
Reply contains invalid hex digit 115
It appears from the openocd log that the error occurs after it has completed writing to flash the main.bin image. Here is the log:
Debug: arm966e.c:139 arm966e_target_command(): chain_pos: 1, variant: arm966e
Debug: jtag.c:1407 jtag_init(): -
Debug: ft2232.c:1300 ft2232_init_ftd2xx(): ‘ft2232’ interface using FTD2XX with ‘comstick’ layout (0640:002c)
Debug: ft2232.c:1389 ft2232_init_ftd2xx(): current latency timer: 2
Debug: ft2232.c:1888 comstick_init(): 80 08 0b
Debug: ft2232.c:1908 comstick_init(): 82 03 03
Debug: ft2232.c:255 ft2232_speed(): 86 01 00
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: TRST asserted
Debug: jtag.c:1197 jtag_reset_callback(): -
Debug: jtag.c:1291 jtag_examine_chain(): JTAG device found: 0x04570041 (Manufacturer: 0x020, Part: 0x4570, Version: 0x0
Debug: jtag.c:1291 jtag_examine_chain(): JTAG device found: 0x25966041 (Manufacturer: 0x020, Part: 0x5966, Version: 0x2
Debug: jtag.c:1291 jtag_examine_chain(): JTAG device found: 0x2457f041 (Manufacturer: 0x020, Part: 0x457f, Version: 0x2
Debug: openocd.c:113 main(): jtag init complete
Debug: embeddedice.c:220 embeddedice_read_reg_w_check(): 4
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: TRST released
Debug: embeddedice.c:220 embeddedice_read_reg_w_check(): 0
Debug: embeddedice.c:384 embeddedice_write_reg(): 0: 0x00000000
Debug: embeddedice.c:220 embeddedice_read_reg_w_check(): 1
Debug: arm7_9_common.c:671 arm7_9_poll(): DBGACK set, dbg_state->value: 0x2cd
Warning: arm7_9_common.c:674 arm7_9_poll(): DBGACK set while target was in unknown state. Reset or initialize target before resuming
Debug: embeddedice.c:384 embeddedice_write_reg(): 0: 0x00000005
Debug: arm7_9_common.c:1047 arm7_9_debug_entry(): target entered debug from ARM state
Debug: arm7_9_common.c:1079 arm7_9_debug_entry(): target entered debug state in Supervisor mode
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r0: 0x600000d3
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r1: 0xe14f1000
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r2: 0xe1500001
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r3: 0x20400001
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r4: 0xe12fff1e
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r5: 0xe52de008
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r6: 0xebfffc24
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r7: 0xe3a00000
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r8: 0xe49de008
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r9: 0xe12fff1e
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r10: 0xe1500001
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r11: 0x20400001
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r12: 0xe1a010a1
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r13: 0xe1500001
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r14: 0x20400001
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r15: 0x5001d11c
Debug: arm7_9_common.c:1114 arm7_9_debug_entry(): entered debug state at PC 0x5001d11c
Debug: target.c:469 target_call_event_callbacks(): target event 0
Debug: arm7_9_common.c:1431 arm7_9_resume(): -
Debug: arm7_9_common.c:1230 arm7_9_restore_context(): -
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): examining User mode
Debug: arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r0
Debug: arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: pc
Debug: arm7_9_common.c:1309 arm7_9_restore_context(): writing register 0 of mode User with value 0x600000d3
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): examining FIQ mode
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): examining IRQ mode
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): examining Supervisor mode
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): examining Abort mode
Debug: arm7_9_common.c:1246 arm7_9_restore_context(): examining Undefined mode
Debug: arm7_9_common.c:1349 arm7_9_restore_context(): writing PC with value 0x5001d11c
Debug: embeddedice.c:384 embeddedice_write_reg(): 0: 0x00000004
Debug: target.c:469 target_call_event_callbacks(): target event 4
Debug: arm7_9_common.c:1534 arm7_9_resume(): target resumed
Debug: embeddedice.c:384 embeddedice_write_reg(): 2: 0x00000001
Debug: arm7_9_common.c:707 arm7_9_assert_reset(): target->state: debug_running
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: SRST asserted
Debug: ft2232.c:1073 comstick_reset(): trst: 0, srst: 1, high_output: 0x01, high_direction: 0x03
Debug: arm7_9_common.c:929 arm7_9_halt(): target->state: reset
Debug: arm7_9_common.c:773 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:295 jtag_call_event_callbacks(): jtag event: SRST released
Debug: ft2232.c:1073 comstick_reset(): trst: 0, srst: 0, high_output: 0x03, high_direction: 0x03
Debug: openocd.c:117 main(): target init complete
Debug: openocd.c:121 main(): flash init complete
Debug: openocd.c:125 main(): NAND init complete
Debug: openocd.c:129 main(): pld init complete
Debug: gdb_server.c:1484 gdb_init(): gdb service for target arm966e at port 3333
Debug: arm7_9_common.c:671 arm7_9_poll(): DBGACK set, dbg_state->value: 0x10d
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r1: 0x600000d7
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r12: 0x50014410
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r15: 0x00000000
Debug: arm7_9_common.c:1114 arm7_9_debug_entry(): entered debug state at PC 0x0
Debug: arm7_9_common.c:929 arm7_9_halt(): target->state: halted
Warning: arm7_9_common.c:933 arm7_9_halt(): target was already halted
Debug: gdb_server.c:136 gdb_get_char(): received ‘$qSupported#37’
Info: server.c:67 add_connection(): accepted ‘gdb’ connection from 0
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘$’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qSupported’
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$#00’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$Hc-1#09’
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘+’
Warning: gdb_server.c:255 gdb_get_packet(): acknowledgment received, but no packet pending
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘Hc-1’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$qC#b4’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qC’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$qOffsets#4b’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qOffsets’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$?#3f’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘?’
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$S02#b5’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$Hg0#df’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘Hg0’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$pf#d6’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘pf’
Debug: gdb_server.c:672 gdb_get_register_packet(): -
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$00000000#80’
Debug: gdb_server.c:136 gdb_get_char(): received ‘$m0,4#fd’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘m0,4’
Debug: gdb_server.c:826 gdb_read_memory_packet(): addr: 0x00000000, len: 0x00000004
Debug: arm7_9_common.c:1779 arm7_9_read_memory(): address: 0x00000000, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$e0f19fe5#65’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$qRcmd,72657365742068616c74#72’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qRcmd,72657365742068616c74’
Debug: target.c:1446 handle_reset_command(): -
Debug: arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r1
Debug: arm7_9_common.c:1309 arm7_9_restore_context(): writing register 1 of mode User with value 0x600000d7
Debug: arm7_9_common.c:1349 arm7_9_restore_context(): writing PC with value 0x00000000
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$OK#9a’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$qRcmd,776169745f68616c74#46’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qRcmd,776169745f68616c74’
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$O77616974696e6720666f72207461726765742068616c7465642e2e2e0a#8e’
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r0: 0x00000000
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r1: 0x50009738
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r2: 0x500096d4
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r3: 0x7c000000
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r7: 0x00000004
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r11: 0x50017af8
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r12: 0x50017aec
Debug: arm7_9_common.c:1108 arm7_9_debug_entry(): r13: 0x50017ffc
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$O7461726765742068616c7465640a#6e’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$qRcmd,6d7777203078354330303230333420307830313936#c7’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qRcmd,6d7777203078354330303230333420307830313936’
Debug: arm7_9_common.c:1925 arm7_9_write_memory(): address: 0x5c002034, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:136 gdb_get_char(): received ‘$qRcmd,61726d375f3920666f7263655f68775f626b70747320656e61626c65#2e’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qRcmd,61726d375f3920666f7263655f68775f626b70747320656e61626c65’
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$O666f72636520686172647761726520627265616b706f696e747320656e61626c65640a#fc’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$qRcmd,61726d375f392073775f626b7074732064697361626c65#87’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qRcmd,61726d375f392073775f626b7074732064697361626c65’
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$O736f66747761726520627265616b706f696e74732064697361626c65640a#c7’
Debug: gdb_server.c:136 gdb_get_char(): received ‘$qRcmd,776169745f68616c74#46’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$qRcmd,666c6173682070726f74656374203020302030206f6666#04’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qRcmd,666c6173682070726f74656374203020302030206f6666’
Debug: target.c:836 target_write_u16(): address: 0x00000000, value: 0x00000060
Debug: arm7_9_common.c:1925 arm7_9_write_memory(): address: 0x00000000, size: 0x00000002, count: 0x00000001
Debug: target.c:836 target_write_u16(): address: 0x00000000, value: 0x000000d0
Debug: arm7_9_common.c:1779 arm7_9_read_memory(): address: 0x00000000, size: 0x00000001, count: 0x00000001
Debug: target.c:804 target_read_u8(): address: 0x00000000, value: 0x80
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$O636c65617265642070726f74656374696f6e20666f7220736563746f72732030207468726f7567682030206f6e20666c6173682062616e6b20300a#d6’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$qRcmd,666c617368206572617365203020302030#28’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qRcmd,666c617368206572617365203020302030’
Debug: target.c:836 target_write_u16(): address: 0x00000000, value: 0x00000020
Debug: target.c:836 target_write_u16(): address: 0x00000000, value: 0x00000070
Debug: target.c:804 target_read_u8(): address: 0x00000000, value: 0x00
Debug: target.c:836 target_write_u16(): address: 0x00000000, value: 0x00000050
Debug: target.c:836 target_write_u16(): address: 0x00000000, value: 0x000000ff
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$O65726173656420736563746f72732030207468726f7567682030206f6e20666c6173682062616e6b203020696e2031732031383830303075730a#84’
Debug: gdb_server.c:136 gdb_get_char(): received ‘+$qRcmd,666c6173682077726974652030206d61696e2e62696e2030#e5’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qRcmd,666c6173682077726974652030206d61696e2e62696e2030’
Debug: target.c:550 target_alloc_working_area(): target 0x10032020: allocating 76 bytes for new working area
Warning: target.c:563 target_alloc_working_area(): not enough working area available
Warning: str9x.c:358 str9x_write_block(): no working area available, can’t do block memory writes
Warning: str9x.c:480 str9x_write(): couldn’t use block writes, falling back to single memory accesses
Debug: target.c:836 target_write_u16(): address: 0x00000000, value: 0x00000040
Debug: arm7_9_common.c:1925 arm7_9_write_memory(): address: 0x00000002, size: 0x00000002, count: 0x00000001
Debug: target.c:836 target_write_u16(): address: 0x00000004, value: 0x00000040
Debug: arm7_9_common.c:1925 arm7_9_write_memory(): address: 0x00000004, size: 0x00000002, count: 0x00000001
Debug: target.c:836 target_write_u16(): address: 0x00000004, value: 0x00000070
Debug: arm7_9_common.c:1779 arm7_9_read_memory(): address: 0x00000004, size: 0x00000001, count: 0x00000001
Debug: target.c:804 target_read_u8(): address: 0x00000004, value: 0x80
Debug: target.c:836 target_write_u16(): address: 0x00000004, value: 0x00000050
Debug: target.c:836 target_write_u16(): address: 0x00000004, value: 0x000000ff
Debug: arm7_9_common.c:1925 arm7_9_write_memory(): address: 0x00000006, size: 0x00000002, count: 0x00000001
[deleted]
Debug: arm7_9_common.c:1925 arm7_9_write_memory(): address: 0x00000378, size: 0x00000002, count: 0x00000001
Debug: target.c:836 target_write_u16(): address: 0x00000378, value: 0x00000070
Debug: arm7_9_common.c:1779 arm7_9_read_memory(): address: 0x00000378, size: 0x00000001, count: 0x00000001
Debug: target.c:804 target_read_u8(): address: 0x00000378, value: 0x80
Debug: target.c:836 target_write_u16(): address: 0x00000378, value: 0x00000050
Debug: target.c:836 target_write_u16(): address: 0x00000378, value: 0x000000ff
Debug: target.c:836 target_write_u16(): address: 0x00000378, value: 0x00000040
Debug: arm7_9_common.c:1925 arm7_9_write_memory(): address: 0x0000037a, size: 0x00000002, count: 0x00000001
Debug: gdb_server.c:188 gdb_put_packet(): sending packet ‘$O77726f7465202038393220627974652066726f6d2066696c65206d61696e2e62696e20746f20666c6173682062616e6b2030206174206f6666736574203078303030303030303020696e2031317320373830303075732028302e303738363333206b622f73290a#63’
Debug: gdb_server.c:136 gdb_get_char(): received ‘—+’
Warning: gdb_server.c:206 gdb_put_packet(): negative reply, retrying
Debug: gdb_server.c:136 gdb_get_char(): received ‘$qRcmd,73687574646f776e#e1+++++’
Error: gdb_server.c:224 gdb_put_packet(): unknown character 0x24 in reply, dropping connection
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘q’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x71
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘R’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x52
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘c’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x63
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘m’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x6d
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘d’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x64
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘,’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x2c
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘7’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x37
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘3’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x33
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘6’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x36
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘8’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x38
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘5’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x35
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘4’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x34
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘f’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x66
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘e’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x65
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘#’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x23
Debug: gdb_server.c:248 gdb_get_packet(): character: ‘1’
Warning: gdb_server.c:265 gdb_get_packet(): ignoring character 0x31
Debug: gdb_server.c:136 gdb_get_char(): received ‘$qRcmd,73687574646f776e#e1’
Debug: gdb_server.c:1372 gdb_input(): received packet: ‘qRcmd,73687574646f776e’
Thoughts? This is not a crucial problem but I thought I would report it.
