I have flashed a lot of Arduinos and Teensys over the years, but for my next project I needed to utilize Bluetooth, so I thought a NRF52840 would be a great fit. The Sparkfun board looks like it has everything I’d need for the project and more. I’m a little past what I’m comfortable with, but hey, gotta learn sometime.
I started by working my way through the [Hookup Guide and [Development with Arduino tutorials. I downloaded the adafruit-nrfutil and added adafruit’s boards to my Arduino IDE. I managed to get the Sparkfun variant into the right spot and updated the boards.txt file.
Now it’s time to upload some examples and test out the board! For some reason I am unable to compile anything with Serial for Sparkfun’s variant (error: ‘Serial’ was not declared in this scope). However, I can compile fine for Adafruit Feather, so I’m trying that. The upload always fails with the following error message:
Upgrading target on COM1 with DFU package C:\Users\busby\AppData\Local\Temp\arduino_build_875082\NRF_BLE_Blink.ino.zip. Flow control is disabled, Single bank, Touch disabled
Timed out waiting for acknowledgement from device.
Failed to upgrade target. Error is: No data received on serial port. Not able to proceed.
  File "nordicsemi\__main__.py", line 294, in serial
  File "nordicsemi\dfu\dfu.py", line 235, in dfu_send_images
  File "nordicsemi\dfu\dfu.py", line 200, in _dfu_send_image
  File "nordicsemi\dfu\dfu_transport_serial.py", line 179, in send_start_dfu
  File "nordicsemi\dfu\dfu_transport_serial.py", line 243, in send_packet
  File "nordicsemi\dfu\dfu_transport_serial.py", line 282, in get_ack_nr
nordicsemi.exceptions.NordicSemiException: No data received on serial port. Not able to proceed.
Possible causes:
- Selected Bootloader version does not match the one on Bluefruit device.
    Please upgrade the Bootloader or select correct version in Tools->Bootloader.
- Baud rate must be 115200, Flow control must be off.
- Target is not in DFU mode. Ground DFU pin and RESET and release both to enter DFU mode.
I noticed that my NRF board is always in the bootload mode, no matter what buttons I press, just like some other people on this forum. I’m not as fluent with testing this stuff, so I’m not sure if I have the same problem. Another symptom is that every few minutes the USB Drive associated with the board gets remounted. Not sure what’s going on there.
Any tips?](nRF52840 Development with Arduino and CircuitPython - SparkFun Learn)](SparkFun Pro nRF52840 Mini Hookup Guide - SparkFun Learn)
