Greetings fellow tinkerers.
I recently purchased:
I put everything on stacking headers and changed the TeensyView Jumper settings (Under a microscope) according to the TeensyView Hookup Guide.
I have had this setup before using the original Teensy Audio Shield with the Teensy 3.6 and it worked fine. I decided I wanted to build more of them with the new hardware, so I bought two of each. I also updated all the software I could find to update Including TeensyDuino and the Teensy loader.
For some reason, I can’t get anything to work. When I load the Teensy Audio program with the Alternate (Audio) selection set, I get nothing. When I load the Screen Demo, the onboard LED blinks like it’s updating the screen, but the screen remains blank. I am using the stock example code so I don’t think posting the code would be useful.
Arduino Settings:
Also, if this is not the correct place to ask for help with this, let me know so I can go to the correct place.
