Hi all,
New here, so please be kind ![]()
I’m trying to build a temperature controller of sorts for essentially a relatively low temperature oven (something like 40-50C). The oven is small - it hosts a voltage reference I intend to keep at a known/controlled temperature - and the Vref has an NTC thermistor on it already which I can use.
It seems to me the COM-11288 is ideal for this, but I was expecting sparkfun to have some sort of controller intended to be used with it. I haven’t been able to find that upon a relatively cursory search.
What would be some recommendations? Maybe a specific product, or maybe I need to put together something a little more complicated.
Thank you much in advance for your input.
That could work; we have this warming blanket guide that uses it and several other small components Heating Pad Hand Warmer Blanket - SparkFun Learn - you could swap any parts out if you don’t need them, or would like something else in its place
