Temperature sensors
Hello everyone!
My buddy and I are working on a project where we need to control the temperature of a heating element. We are using a laser to burn stuff, but we dont’ want the laser getting too hot so I thought to use a temperature sensor that shuts of the laser when it gets too hot. Naturally, I looked for decent temperature sensors and found the tmp36. However, my problem is that we are heating things up to 160 C and the tmp36 only goes up to 120 C. Is there another component that would be a good replacement? or what about an alternative solution?
Parts of the laser are getting to 160 Centigrade ?!?
Thermocouples can certainly handle that temp, remote sensing too.
https://www.sparkfun.com/products/251
https://www.sparkfun.com/products/9570
Sorry, the laser itself isn’t getting up to 160 C, it’s the element that it will be heating.
Look into using an RTD or a thermocouple for sensing.
a google search will find you lots of info.
Thanks a bunch! I googled RTD elements and found this little solution:
http://www.omega.com/pptst/F1500_F2000_F4000.html
