Hello.
I need the template to print a postcard box.
I need a 5/8" thread to fit a measuring stick.
Can Sparkfun or someone provide me with a file?
Thank you very much.
Angel
Hello.
Angel
Hello, what file are you looking for? What format?
5/8" 11 threads per inch
Could perhaps also make a cavity for a hex nut to push into place.
Hello. In step format, for example.
Just use a cellphone holder and a case and attach it to the pole then run the antenna wire to the antenna.
Hello. I saw a really nice enclosure in one of your posts. Could you send me the file to print? Thanks.
Hi Aorpls, thank you for the email. You know your email arrived without any attachments. Could you check that? Thank you very much, Angel.
Hello Aorpls.
Thanks for the files. Regards.
Angel
I’ll try to use your files and add a 5/8" thread.
If I succeed, I’ll send you the file.
