it also seems like the code is for a 4MHz clock. I’m using 20. Here is the code:
DELAYS AND TIMING
Delays are frequently used. There are various
ways to generate them:
Instruction cycle counting
Using the TMR0 timer
Watchdog timeout for low power consumption
Using variables achieves longer delays
void delay_ms( uns16 millisec)
// Delays a multiple of 1 milliseconds at 4 MHz
// using the TMR0 timer
char next = 0;
OPTION = 2; // prescaler divide TMR0 rate by 8
TMR0 = 2; // deduct 2*8 fixed instruction cycles delay
do {
next += 125;
clrwdt(); // needed only if watchdog is enabled
while (TMR0 != next) // 125 * 8 = 1000 (= 1 ms)
} while ( – millisec != 0);
void delay10( char n)
Delays a multiple of 10 milliseconds using the TMR0 timer
Clock : 4 MHz => period T = 0.25 microseconds
1 IS = 1 Instruction Cycle = 1 microsecond
error: 0.16 percent
char i;
OPTION = 7;
do {
clrwdt(); // only if watchdog enabled
i = TMR0 + 39; /* 256 microsec * 39 = 10 ms */
while ( i != TMR0)
} while ( --n > 0);
void _delay10( char x)
using instruction cycle counting
Clock : 32768 Hz => period T = 30.518 microseconds
1 Instruction Cycle = 1 IS = 4 * T = 122 microseconds
10 ms = 82 IS (81.92) => error: 0.1 percent
do {
char i = 26; /* 2 IS */
do ; while ( --i > 0); /* 26 * 3 - 1 = 77 IS */
} while ( --x > 0); /* 3 IS */
char counterT;
void maintimer( void)
if ( TO == 1) {
/* power up or MCLR */
PORTA = 0; /* write output latch first */
TRISA = 0; /* all outputs */
TRISB = 0xFF; /* all inputs */
else {
/* watchdog wakeup */
if ( --counterT > 0) {
OPTION = 0x0B; /* WDT divide by 16 */
sleep(); /* waiting 16 * 18 ms =
288 ms = 0.288 seconds */
delay_ms( 5500); /* 5.5 seconds */
delay10( 100); /* 1 second */
counterT = 7; // 7 * 0.288 sec. = 2 sec. totally
OPTION = 0x0B; // 0 1011: WDT divide by 16
// main terminates by sleep();, allows low power consumption
// waiting for watchdog timeout: approx. 16*18 ms = 288 ms
