The right board for the job
Hello everyone, we are looking to make our own gnss receivers and found this website that contains boards for pretty much every application.
I am looking at monitoring small ground movement (mm to cm scale movement every month) so I was wondering if others here have built anything systems like this and can tell me what chips and peripherals they recommend.
Basically I would like to know which chips are the most accurate to deploy on the site and what other pieces (aside from a case and power supply) would I need to make this product.
Thank you
This is a big topic… That’s why we wrote tutorials!
https://learn.sparkfun.com/tutorials/wh … ps-rtk/all
https://learn.sparkfun.com/tutorials/ho … tation/all
I’d recommend a local base station with a rover staked into whatever spot you’re monitoring. You may want to capture RAWX and then do post processing. Trying to measure mm movement will be tricky but I know there are lots of SparkFun customers doing just that on glaciers and other scientific applications. Other folks on the forum may have additional thoughts.
Thank you Sparky. We got the units we needed and are charging the units using solar panels, Li batteries, and a solar charge controller
BTW, Sparky, it would suggest you to improve the tutorial about base station installation. The antenna is not installed in a well open place. See [NRCAN recommendations.
If you’re using CSRS-PPP service for coordinates calculation and the station is in North America, I would suggest get results in NAD83 to avoid plate motion glitches between nearby stations.](https://natural-resources.canada.ca/sites/nrcan/files/earthsciences/pdf/BestPractices_GNSS_Reference_Station.pdf)
And for the initial question, do you want real time measurements or can you accept afterwards calculations?
You may have a look at this [glacier tracking.](https://wiki.eclipse.org/images/7/7d/Eid2023_friedt.pdf)
