Transmitter & Receiver sharing same antenna
I plan to setup the TLP-434A type modules with a xmtr and rcvr that share a common antenna, running half-duplex on the same frequency.
I have a design (only on paper) that does T/R switching using a pair of PIN diodes, an inductor, a couple of C’s, and a couple of R’s. A PIC will be available to do the T/R switching, so it’s not necessary for it to be ‘automatic’.
Has anyone tried anything similar?
Is there a simpler way that is effective?
Given that the xmtr is rather low-power, is there any danger of damaging the front end of the rcvr?
Pete
Linx has a nice tech note on creating a transceiver here http://www.linxtechnologies.com/linx-kb … 23&lang=en
I’ve done this with a pair of TLP/RLP, but never with a shared direct
antenna connection. I used a Philips SA630 SPDT RF switch.
Thanks Bruce!
The SA630 (or something similar) looks like the way to go.
Pete
Hi Pete,
You’re welcome.
Let me know if you need a couple of the SA630. I can toss a few in an
envelope for you. We have a few spares left over from an old job.
They’re 8-pin SO surface mount package, but still easy to hand solder.
Thanks Bruce! I sent you an e-mail at the Rentron “tech” address.
Pete
