Trouble getting PL2303TA USB to TTL working on Arduino
Has anyone here tried connecting a PL2303TA USB to TTL with an Arduino? I thought the wiring was simple, but mine doesn’t seem to be recognized properly on Windows 11. The device manager just throws a driver error. Not sure if I’m missing something or if it’s just the driver issue people keep mentioning.
I used PL2303TA with a customized Arduino Board. I faced no problem. Please check your jumper wires.
Yeah, I ran into the same problem before. The wiring part is straightforward (5V → 5V, GND → GND, TX ↔ RX, RX ↔ TX), but the driver was the actual issue. The fix for me was grabbing the Windows 11 compatible driver for the PL2303TA USB to TTL and installing it in compatibility mode. After that, it finally showed up properly and I could upload sketches without problems.
Oh. So it was a matter of version incompatibility. Good to know that the problem is solved.
