i have been trying to get the DHT11 to work on my mega2560 for a few days now but cant seem to get it to verify the sketch. i have been using the test code, .h , and .cpp files on the arduino website found here http://playground.arduino.cc/Main/DHTLib I place the dht.h and the dht.cpp files in the same folder named DHT and upload them as the library. when i try to verify the test sketck i recive the error code “DHT does not name a type”
//    FILE: dht_test.ino
//  AUTHOR: Rob Tillaart
// VERSION: 0.1.07
// PURPOSE: DHT Temperature & Humidity Sensor library for Arduino
//     URL: http://arduino.cc/playground/Main/DHTLib
// Released to the public domain
#include <dht.h>
dht DHT;  //here is where it tells me that DHT does not name a type
#define DHT11_PIN 4
//#define DHT21_PIN 5
//#define DHT22_PIN 6
void setup()
  Serial.println("DHT TEST PROGRAM ");
  Serial.print("LIBRARY VERSION: ");
  Serial.println("DHT_LIB_VERSION");
  Serial.println();
  Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)");
void loop()
  /* READ DATA
  Serial.print("DHT22, \t");
  int chk = DHT.read22(DHT22_PIN);
  switch (chk)
    case DHTLIB_OK:
		Serial.print("OK,\t");
		break;
    case DHTLIB_ERROR_CHECKSUM:
		Serial.print("Checksum error,\t");
		break;
    case DHTLIB_ERROR_TIMEOUT:
		Serial.print("Time out error,\t");
		break;
    default:
		Serial.print("Unknown error,\t");
		break;
  // DISPLAY DATA
  Serial.print(DHT.humidity, 1);
  Serial.print(",\t");
  Serial.println(DHT.temperature, 1);
  delay(1000);
    // READ DATA
  Serial.print("DHT21, \t");
  chk = DHT.read21(DHT21_PIN);
  switch (chk)
    case DHTLIB_OK:
		break;
		break;
		break;
    default:
		break;
  // DISPLAY DATA
  delay(1000);
 */ // READ DATA
  Serial.print("DHT11, \t");
  chk = DHT.read11(DHT11_PIN);
  switch (chk)
    case DHTLIB_OK:
		break;
		break;
		break;
    default:
		break;
 // DISPLAY DATA
  Serial.print(DHT.humidity,1);
  Serial.println(DHT.temperature,1);
  delay(1000);
// END OF FILE
can someone pls let me know what iam doing wrong and help me in the right direction to get it working
