TSH82 Capacitor operating voltage
hello
I looked at the THS82 datasheet, Configurable Op Amp Board, and was unable to obtain information about the voltage level supported by the DC level blocking capacitors, C6 to C9, 1uF.
I will use the equipment to transform a differential signal into a single ended one with this equipment. Could it support DC voltage level around 12V on these capacitors?
What is the Operating Voltage?
Thanks for the help!
The 1.0 uF caps are # NMC0603Y5V105Z16TRPF, looks like 16v max to me? https://4donline.ihs.com/images/VipMast … 353EA87419
