TSL235R Light to Frequency Converter
Hi, I am a newcomer in the arduino field. I am interested in having a light sensor for the detection of light, particularly the detection of rapidly changing low light levels. In this respect, the TSL235R LtoFC seems to be a very good option for a sensor. Although it is possible to find many codes for doing light level measurements using TSL 235R, it is evident that the proper coding implies a deep understanding of the inner working of the arduino system (i.e. timers) and arduino syntax. I want and need to implement a system for light sensing using the TSL235R LtoFC for what I would appreciate if someone can explain in a general way (or indicate were to find such an explanation) the communication between the TSL235R sensor, signals and the arduino hardware and syntax. Best,
You must have forgoten to ask google.
