Tsunami now having trouble reading SD card
Having new problem with previously working Tsunami Super Wave Trigger. Hoping you can point me in the right direction.
Card has been working fine until yesterday. Using 6 audio output channels controlled by I2C port. Files on SanDisk Ultra 256G uSD card.
I swapped two of the output channel connectors. Used manual trigger to test that the output channels were routed to the right amps. Seemed to be working correctly for a few minutes, then I started to lose files - one at a time then they all stopped responding. I removed the SD card and checked it on my computer. I reformatted the card and re-wrote the directory image and verified all files were OK using my computer. When inserted into the Tsunami, the blue LED is blinking and no audio. I rechecked the SD card on my PC and in the Tsunami again - same blinging LED and no audio. I bought a new SanDisk 256G uSD card and loaded the .wav files and .ini file and same blinking LED with no audio.
Documentation says format using FAT32 but that has been replaced by exFAT format. I doubt this makes a difference since it has been working for quite a while, but any chance Tsunami is sensitive to the SD card format?
You can see what I have tried with the SC card. I have tried manually resetting the card (no change). I have tried cycling the power (no change). No wiring or other wiring changes except the audio connectors swap mentioned above.
What do you think?
BR,
-Greg R.
Use another SD card reader to see if the issue persists when the card is read on a different device. This can help rule out problems with the SD card reader in the Tsunami.
All Robertsonics audio players require either FAT16 or FAT32 formatting. exFAT, and therefore microSD cards larger than 32GB, are not supported. You may be able to format your 256GB as FAT32, but you’ll only be using 32GB.
