Two Marvell Kirkwood CPU's in JTAG chain.
Hello i’m trying to load U-boot ELF image into two identical Marvell Kirkwood based boards.
I have them connected in JTAG chian like:
JTAG TDI → board1 TDI
board1 TDO → board2 TDI
board2 TDO → JTAG TDO
TCK, TMS, TRST, NRST, GND, VCC signals are common for two boards.
Here is my OpenOCD board configuration file.
source [find interface/sheevaplug.cfg]
set CHIPNAME board1
source [find target/feroceon.cfg]
$_TARGETNAME configure \
	-work-area-phys 0x10000000 \
	-work-area-size 65536 \
	-work-area-backup 0
set CHIPNAME board2
        -work-area-backup 0
arm7_9 dcc_downloads enable
# this assumes the hardware default peripherals location before u-Boot moves it
set _FLASHNAME $_CHIPNAME.flash
nand device $_FLASHNAME orion 0 0xd8000000
proc sheevaplug_init { } {
	# We need to assert DBGRQ while holding nSRST down.
	# However DBGACK will be set only when nSRST is released.
	# Furthermore, the JTAG interface doesn't respond at all when
	# the CPU is in the WFI (wait for interrupts) state, so it is
	# possible that initial tap examination failed.  So let's
	# re-examine the target again here when nSRST is asserted which
	# should then succeed.
	jtag_reset 0 1
	board1.cpu arp_examine
	board2.cpu arp_examine
	halt 0
	jtag_reset 0 0
	wait_halt
	arm mcr 15 0 0 1 0 0x00052078
	mww 0xD0001400 0x43000C30 #  DDR SDRAM Configuration Register
	mww 0xD0001404 0x39543000 #  Dunit Control Low Register
	mww 0xD0001408 0x22125451 #  DDR SDRAM Timing (Low) Register
	mww 0xD000140C 0x00000833 #  DDR SDRAM Timing (High) Register
	mww 0xD0001410 0x000000CC #  DDR SDRAM Address Control Register
	mww 0xD0001414 0x00000000 #  DDR SDRAM Open Pages Control Register
	mww 0xD0001418 0x00000000 #  DDR SDRAM Operation Register
	mww 0xD000141C 0x00000C52 #  DDR SDRAM Mode Register
	mww 0xD0001420 0x00000042 #  DDR SDRAM Extended Mode Register
	mww 0xD0001424 0x0000F17F #  Dunit Control High Register
	mww 0xD0001428 0x00085520 #  Dunit Control High Register
	mww 0xD000147c 0x00008552 #  Dunit Control High Register
	mww 0xD0001504 0x0FFFFFF1 #  CS0n Size Register
	mww 0xD0001508 0x10000000 #  CS1n Base Register
	mww 0xD000150C 0x0FFFFFF5 #  CS1n Size Register
	mww 0xD0001514 0x00000000 #  CS2n Size Register
	mww 0xD000151C 0x00000000 #  CS3n Size Register
	mww 0xD0001494 0x003C0000 #  DDR2 SDRAM ODT Control (Low) Register
	mww 0xD0001498 0x00000000 #  DDR2 SDRAM ODT Control (High) REgister
	mww 0xD000149C 0x0000F80F #  DDR2 Dunit ODT Control Register
	mww 0xD0001480 0x00000001 #  DDR SDRAM Initialization Control Register
	mww 0xD0020204 0x00000000 #  Main IRQ Interrupt Mask Register
	mww 0xD0020204 0x00000000 #              "
	mww 0xD0010000 0x01111111 #  MPP  0 to 7
	mww 0xD0010004 0x11113322 #  MPP  8 to 15
	mww 0xD0010008 0x00001111 #  MPP 16 to 23
	mww 0xD0010418 0x003E07CF #  NAND Read Parameters REgister
	mww 0xD001041C 0x000F0F0F #  NAND Write Parameters Register
	mww 0xD0010470 0x01C7D943 #  NAND Flash Control Register
Here is OpenOCD log:
  • Open On-Chip Debugger 0.4.0 (2010-10-01-13:56)
    Licensed under GNU GPL v2
    For bug reports, read
    http://openocd.berlios.de/doc/doxygen/bugs.html
    200 kHz
    trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain
    jtag_nsrst_delay: 200
    jtag_ntrst_delay: 200
    dcc downloads are enabled
    Warn : use ‘board1.cpu’ as target identifier, not ‘0’
    Info : clock speed 200 kHz
    Info : JTAG tap: board1.cpu tap/device found: 0x20a023d3 (mfg: 0x1e9, part: 0x0a02, ver: 0x2)
    Info : JTAG tap: board2.cpu tap/device found: 0x904023d3 (mfg: 0x1e9, part: 0x0402, ver: 0x9)
    Warn : JTAG tap: board2.cpu UNEXPECTED: 0x904023d3 (mfg: 0x1e9, part: 0x0402, ver: 0x9)
    Error: JTAG tap: board2.cpu expected 1 of 1: 0x20a023d3 (mfg: 0x1e9, part: 0x0a02, ver: 0x2)
    Warn : Unexpected idcode after end of chain: 64 0x0000007f
    Warn : Unexpected idcode after end of chain: 128 0x0000007f
    Warn : Unexpected idcode after end of chain: 160 0x0000007f
    Warn : Unexpected idcode after end of chain: 288 0x8000007f
    Warn : Unexpected idcode after end of chain: 384 0x0000007f
    Warn : Unexpected idcode after end of chain: 448 0x0000007f
    Warn : Unexpected idcode after end of chain: 480 0x0000007f
    Warn : Unexpected idcode after end of chain: 608 0x0000007f
    Error: double-check your JTAG setup (interface, speed, missing TAPs, …)
    Info : JTAG tap: board2.cpu tap/device found: 0x20a023d3 (mfg: 0x1e9, part: 0x0a02, ver: 0x2)
    Info : Embedded ICE version 0
    Info : board1.cpu: hardware has 1 breakpoint/watchpoint unit
    Info : board2.cpu: hardware has 1 breakpoint/watchpoint unit
  • Here is telnet session log:
  • vic@ws-024:~$ telnet localhost 4444
    Trying ::1…
    Trying 127.0.0.1…
    Connected to localhost.
    Escape character is ‘^]’.
    reset
    targets
    TargetName Type Endian TapName State
    0* board1.cpu feroceon little board1.cpu running
    1 board2.cpu feroceon little board2.cpu running
    invalid mode value encountered 0
    cpsr contains invalid mode value - communication failure
    ThumbEE – incomplete support
    target state: halted
    target halted in ThumbEE state due to debug-request, current mode: System
    cpsr: 0xffffffff pc: 0xfffffff9
    MMU: enabled, D-Cache: enabled, I-Cache: enabled
    invalid mode value encountered 4
    sheevaplug_init
    Halt timed out, wake up GDB.
    timed out while waiting for target halted
    Command handler execution failed
    in procedure ‘sheevaplug_init’ called at file “command.c”, line 650
    in procedure ‘wait_halt’ called at file “/usr/share/openocd/scripts/board/two_boards.cfg”, line 43
    called at file “command.c”, line 361
    timeout waiting for SYSCOMP & DBGACK, last DBG_STATUS: 0
    target halted in Thumb state due to debug-request, current mode: FIQ
    cpsr: 0x00002a31 pc: 0xffffffea
    Error: invalid mode value encountered 0
    Error: cpsr contains invalid mode value - communication failure
  • So finally I can not invoke load_image /srv/tftp/u-boot and resume 0x00600000
    The question is what am I doing wrong and has anybody tried to connect two kirkwood boards in JTAG chain.
