Hi, I have six Silver Mates I just bought a week or so ago. I am connecting them to an arduino mega on Serial1, although I’ve tried Serial2, Serial3, and an Arduino Pro Mini - they both WERE working fine, but I have tried experimenting with them by getting into command mode $$$ and changing things. I have done so carefully and have not issued commands that would brick the unit (or so I believe).
They were working fine and then stopped working fine. The behavior is that they go into blinking at 2 times per second instead of 1 or 10 (data mode or command mode) and they no longer respond to just about anything. The first one worked fine for a while, going in and out of command mode, and then nothing. The second worked for a while as well, and then it happened to this one.
I have tried factory resetting them by soldering a wire to the GPIO4 and then following the procedure with the toggle 3 times etc. and I’ve tried that 20 times each and IT DOES NOT WORK.
What has happened to my modules? I can’t afford for this to happen to the others. Blinking twice per second is labeled as “not in config mode but still timing down.” WHAT does that mean? If it’s not in config mode, what mode is it in? It’s not in data mode because it doesn’t accept $$$ any longer.
THANK YOU!
