Hi all
I am working on designing a device that has two ZigBee modules in it. The reason is to split some functionality and processor intensive tasks between them.
I have heard that if I place them far enough, then its not a big problem to get FCC. However if they are deemed co-located by FCC-lab then it can be quite an expensive problem to get them certified.
IS this right, and of so what minimum distance should separate them.
To make this clear, both device will be using “listen before transmit” so will not be transmitting at the same time. Also the transmit power will be fairly low.
