UBLOX boards on back order.
A number of the Sparkfun GNSS boards are marked as on back order, with no delivery date.
The U-Blox website says that chips such as the ZED-F9P are delayed by 8 weeks because of supply problems. Is that the reason that the boards are on back order?
I also see that the antenna ground plane is marked as retired. That’s a nuisance, because it’s a nice clean solution if you use an antenna that requires one. Is there an alternative ground plane or do I have to go back to doing my own metalwork?
Yep, they are having a hard time getting their chips :-/
I’d say that yes, for now, it might be easiest to just make your own ground plane(s) until we have found a new product/supplier for those
Try this link for the ground plane. :slight_smile:
https://www.sparkfun.com/products/17519
