Hello everyone,
I’ve hit a programming snag and figure it’s a good time to set up a “real” debugging option (i.e. not blinking an LED/uart_printf) before imposing on others for troubleshooting. I’ve spent the evening trying to understand my options, and want to make sure I actually know what’s going on.
My hardware is an ARM9 (s3c2440) dev board and a parallel port Wiggler. I am using Eclipse + YAGARTO. I’ve been programming using the bootloader and DNW terminal. The board came packaged with H-JTAG. I want to be able to step through my code, monitor registers, and the like. I’d still like to use the bootloader if that’s of any consequence.
As I understand it (and please correct me because I have a feeling I’m way out there),
Eclipse interfaces with GDB and provides me with a GUI for debugging that makes life easier.
YAGARTO includes GDB, which does the debugging voodoo.
I need to interface GDB to my hardware. This is where OpenOCD comes in.
The H-JTAG server plays the same role as OpenOCD, but won’t work with Eclipse because it uses the RDI interface.
OpenOCD just needs to be pointed toward the parallel port (interfaces/parport.cfg), and told to look for my chip (target/samsung_s3c2440.cfg), in Eclipse.
Is that the long and short of it? Other recommended options?
