Does it come with a programming cable? and power adapter?
You get just the Uno, you need a regular [USB A to B cable for programming and power. These are fairly common and the same type of cable typically used with a USB printer so you might already have one at home. ![]()
Thank you!
My programmer knows C and C++. Can you recommend a good Arduino programming book?
Thank you.
