usb mounting in arm based lpc3250
hi,
i am new to linux as well as usb,which i am using in one of my project.
I am having LPC3250 board,which i have configured in Host mode,using the menuconfig(linux kerenl 2.6.34).When i am attaching a USB device to the usb port,the device is getting detected which i am think based on my below observation
1.USB led blinking
2.In the linux ported on lpc3250 board file system when i am using this command mdev -s , sda is appearing in the dev directory
But when i try to mount the usb using this command mount /dev/sda1 /media1
it is giving this problem as mentioned below
usb 1-1: reset full speed USB device using usb-ohci and address 10
sd 8:0:0:0: [sda] Unhandled error code
sd 8:0:0:0: [sda] Result: hostbyte=0x07 driverbyte=0x00
sd 8:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 02 00 00 02 00
end_request: I/O error, dev sda, sector 2
EXT2-fs (sda): error: unable to read superblock
sd 8:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
end_request: I/O error, dev sda, sector 0
Buffer I/O error on device sda, logical block 0
sd 8:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 10 00
Buffer I/O error on device sda, logical block 1
sd 8:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 08 00 00 10 00
end_request: I/O error, dev sda, sector 8
Buffer I/O error on device sda, logical block 2
sd 8:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 10 00 00 10 00
end_request: I/O error, dev sda, sector 16
Buffer I/O error on device sda, logical block 3
sd 8:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 18 00 00 08 00
end_request: I/O error, dev sda, sector 24
sd 8:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 01 00
FAT: unable to read boot sector
mount: mounting /dev/sda on /media failed: Input/output error
Please help me out with this problem as i am struck in it for over a month.
Please do reply if i am not clear in presenting my problem.
