USB to FTDI connector
I am trying to source a cable or adapter that connects a 0.5" header pin part on motherboard to computer. Are there any such products available
Hi Vishwarath,
SparkFun does not really carry parts or cables to connect internals on a computer so I am not sure we will have something like this. If you want to browse to see if we have something that could work, the [Cables Category has all cables/wires we carry. You may want to look for this type of cable/adapter at a company that specializes in computer parts.](Cables - SparkFun Electronics)
The FTDI cable is a USB to Serial (TTL level) converter which allows for a simple way to connect TTL interface devices to USB. The I/O pins of this FTDI cable are configured to operate at 5V. The FTDI cable is designed around an FT232RQ, which is housed in a USB A connector.
