Which is the best and freely available USB utility software on the net…
I mean to say , the USB utility similar to Hyperterminal e.t.c…
I would like to use this, to test one of the OLIMEX boards serial to USB …
You can just use hyperterminal.
The board should appear as a virtual com port to the computer so you just use hyperterminal like you normally would with a serial connection.
