Using Keil and ULINK2 to debug code on SoarkFun Edge Development board
I am trying to use the Keil ULINK2 debug probe with the Sparkfun Edge Development Board – Appollo3 Blue with its JTag connector.
However, downloading to the board using the ULINK2 fails due to SWD communication failure.
Can I use the ULINK2 probe with this board? If not, which debug probe is compatible with this board?
I am unfamiliar with the ULINK2 probe - I do know that the SEGGER J-LINK probes have worked well in my experience. You probably already know but the connection should be made from the bottom of the board - i.e. on the same side as the coin cell holder.
Thanks for your response. Yes, I am aware of the connection layout for the J-Tag connector. In this case, I may have to acquire a J-Link probe.
You would probably also be interested in this thread: viewtopic.php?f=168&t=51651&p=210426&hi … on#p210426
