Hello !
I have bought the redbot and a couple of xbees from sparkfun. I want to use the xbees to control the robot remotely.
the robot motors with a sample sketch work fine, with the redbot library.
the xbees work fine with the arduino xbee library. In API mode, I can send messages from the PC to the robot.
I use xbee’s software serial through SoftwareSerial.h, and I can specify the correct pins on the redbot, like this :
SoftwareSerial nss(15, 14); // RX, TX
Trouble is, if I add RedBot.h to my sketch, it doesn’t compile anymore, presumably because it has its own “RedBotSoftwareSerial”. However, as documented, “RedBotSoftwareSerial” does not let me choose the PINs I need.
(“You no longer have a choice of which pins to use–the library always uses A0 and A1, which are the pins connected to the XBee module footprint.”)
How could I work around this ?
Regards,
alex
