Voice over Bluetooth
What would I need in addition to a pair of transceiver modules http://www.sparkfun.com/shop/index.php? … ansceiver& to create a wireless link for a microphone.
Do the bluetooth trancevers support an anologue signal or would I need to use a A/D convertor
The link would be strictly one way with a low ouput required from the reciver.
Any sugestions apreciated.
P
Can anyone even point me in the right direction for which A/D and D/A (serial) would be best for this application?
PJT:
I think the best way would be to use the PCM functionality of these radios assuming that you want to transmit voice frequencies. If so, you would need a pcm codec.
Here is an example. http://rocky.digikey.com/WebLib/Texas%2 … IC1103.pdf
Many thanks, that is just what I need!
