As the title suggests, I want to use the Artemis for a business that includes taking simple readings (temperature readings using thermistor tests). With my current MCU, it’s simple, as I can just use high efficiency from an advanced spindle, but that’s not really an option here.
I am concerned about the power usage so I should have the option to turn the test circuit on and off. Again, pretty straightforward using the advanced pin.
I’m decently new to this area, and several general thoughts, but I might really want to hear from more experienced people on the prescribed procedures and assumptions.
The perspectives I have considered are:
Using a voltage divider, but the test circuit itself is a voltage divider circuit, so I don’t know what the impact of their bonding will be, or what the force contemplations look like here
Using a BJT semiconductor as a change from an external power source and then using LDO or Zener diode (s) to further reduce the voltage depending on the situation.
Very appreciated
