Wav trigger and due
Hi and thank you for your hard work and time.
I would like to use a due to trigger output sounds thru the wav trigger. I would like to use the softserial library and use the
Digital output pins to communicate via serial port of the wav trigger. Is there a voltage difference in the serial ports. I can’t find specs of the serial ports. I hope that came out right. Thank you
Wave trigger can tolorate 3.3V as well as the Due, so you should be good.
Thank you
