Wearable heart rate monitor
My kids in middle school decided to work on a project that involves a heart rate monitor. Your website recommends LilyPad Arduino product line. Could you please provide some advice on what I would need to purchase to have a functional wearable heart rate monitor that uses LEDs and any instructions that they can use to put the parts together.
Thanks an look forward to hearing from you soon.
Hi ndugup, and thanks for writing.
We don’t carry a sensor that would easily connect to a wearable board like a LilyPad, but the Pulse Sensor can easily connect to a board like the Arduino Uno or a SparkFun RedBoard. You might be able to attach those to clothing somehow and make your project that way.
I’d start with the following:
  • - [[SparkFun RedBoard](https://www.sparkfun.com/products/15123) (The 'Brain' that reads the Pulse Sensor)
  • - [[Pulse Sensor](https://www.sparkfun.com/products/11574) (Senses your pulse/heart rate)
  • - [[4x AA battery pack](https://www.sparkfun.com/products/9835) (To make this portable later on)
  • [/list]
    Those parts and some sample code will allow you to view a graph on your computer screen of blood flow detected by the pulse sensor and the code will also light up a LED on the RedBoard when a heartbeat is detected. There’s some [sample code here to get you started.
    Hope this helps!](GitHub - WorldFamousElectronics/PulseSensorStarterProject: The Best Way to Get Started with your PulseSensor and Arduino)](https://www.sparkfun.com/products/9835)](Pulse Sensor - SEN-11574 - SparkFun Electronics)](SparkFun RedBoard Qwiic - DEV-15123 - SparkFun Electronics)
    Thank you very much Chris for your advice. Would I need to get the LED or does it come already with the RedBoard…please let me know if there is anything else such as cables, connectors, etc that are required as I am trying to make sure I get everything that I need in one transaction.
    Kind regards,
    Pandy
    Hi Pandy.
    There’s a LED already on the RedBoard that will light up for you but you could add external LEDs if you wish.
    The only cable you will need is a micro USB data cable to connect the RedBoard to your computer for programming. Our part number [CAB-10215 will work if you don’t already have one.](USB Micro-B Cable - 6 Foot - CAB-10215 - SparkFun Electronics)
