Hi all,
I was probing a custom PCB and simultaneously had it hooked to an oscilloscope and noticed some weird behavior. When I touch the first multimeter probe to any pin, I see an oscillation (always drop in voltage first) on the oscilloscope [photo below]. Thought this was weird behavior, so I tried it on a sparkfun Redboard Artemis – same thing. Then I tried simply touching the board with the multimeter probe not attached to the multimeter–same result. These boards were hooked up first to power supply, then to battery.
What exactly is this, and how can I mitigate it? I would expect ESD to have a positive voltage spike. Interestingly, if I touch exposed metal on the PCB a second time, the oscillation does not occur, leading me to think there is some sort of charging going on…
Thank you for the insights–lots to learn!
