What ARM-derivates are supported
hello community,
what chip series based on the arm7-architecture can be (flash-) programmed and debugged with openocd.
regards klaus
Hello Klaus,
so far, the on-chip flash found on Philips LPC2000, Atmel SAM7 and ST Micro. STR7x controllers can be programmed. Additionally, there’s support for external CFI-compatible flashes using the Intel commandset.
If flash programming isn’t required, the OpenOCD should work with any ARM7TDMI or ARM720t based arm7 system.
Regards,
Dominic
