Hi guys. I want to isolate my power supplies (have two of them) so that they can be populated first and tested and then populate the rest of the board, and also connect an external power supply if required.
Normally I would just use a jumper for this (say between input voltage and the 5v regulator or 5v output and the 3.3v LDO). But I want to avoid the jumper.
I believe there is away to do this on PCBs, but don’t know the name. Something like two SMD resistor pads that get soldered over or opened up when you want to disconnect (would like to avoid a through hole wire “jumper”).
Sorry this is a bit lengthy, but anyone know the proper name for this type of layout/design?
