What electronics do I need?
Dear all,
I am a new member of this community and I would like to have some purchasing advise for my project.
GOAL: I need to develop a small device which will send an E-mail/SMS to a recepient containing GPS location. This should be done with the touch of a button. Battery life should be maximized so the device should be activated only when the button is pressed.
I was thinking about:
GM862 Evaluation Kit - USB
QUESTIONS:
Which Battery and how can I connect it?
Which Button?
How do I integrate the button into the system?
Thanx for the help guys!
Anybody?
gsmgps_combo:
Anybody?
I think you will find very few people willing to jump into a discussion as your propose.
Because there are a million ways to implement this…the conversation could be endless.
You will need to decide the direction you want to take…and ask more specific questions based on that direction. Any other method of figuring it out, would be asking someone to design it for you. I would think people will not want to do this for free. They had to learn, so you will need to do the same, or pay someone to design it for you.
Just my opinion on the situation,
James L
The forum might come across as a bit harsh not replying but you are asking for quite a bit of help.
The eval kit would be fine to get you started and with the addition of a button you could do what you want.
There is however a little more to it than that. YOU will have to read all of the relevant documents and learn Python.
http://www.telit.com/en/products/gsm-gp … c=show&p=7
There are then all of the issues with running python on the Telit units, its fine but has serious pit falls.
I would recommend that you look through all of the relevant manuals before you spend your cash and decide if it is something you want to do or if its something you want someone to do for you.
Also the post is more appropriate for the “Projects” section than the “PCB Design Questions” section.
Thanx for your replies.
I already have someone who’s in charge of the ¨Python part, so no problem on that issue.
The only issue I have is to know what I need to purchase in order to put together the “button” functionality? How is this done?
Thanx again for your replies…
The GM862 can be switched on with a push button, see the Hardware User Manual. You might be able to program it in Python to send a message then switch itself off. It might be easier to control it with an MCU, interface a push button to that, and use it to switch the GM862 on and get it to send the message.
Leon
Dear Leon,
thank you for your reply. Can you advice me where to buy an MCU? Is it available @ Sparkfun?
Can you describe me what I need to purchase?
This would be of great help.
MCU = microcontroller unit. Can you design and program embedded systems?
Leon
designing and programming embedded systems is not a problem, we have a partner who can do this.
Our issue is the hardware, what do we need to purchase?
A suitable MCU, like a PIC or AVR. You will also need to design a PCB for it and the GM862 (and the push button).
Leon
Again, the hardware aspect is not my thing :slight_smile:
could you just help me by giving a specific URL where there are pictures about the different electronics. Maybe on Sparkfun shop?
Thanx in advance, this would help me a great deal.
I thought you said that you had someone on your team that understands hardware. If it helps, I’m using a PIC16F88 to control the similar GE-863.
Leon
gsmgps_combo:
I said that we have someone who’s in charge of the Python part (programming). The “only” thing we need to do is provide him with a device which can be connected to a computer for programming a script.
My question for the forum is what we need to purchase in order to make the device do what I described above.
when is your assignment due?
I think you are stuck unless you can find someone who understands hardware and embedded systems.
Leon
We need to have it finished by the end of april so any help is welcom. I am willing to pay someone to develop the whole device.
If anybody is interested?
In the meanwhile, the only thing I need is a shopping list, can anyone please help me with a short but detailed explanation?
Thanx in advance guys!
Leon,
I truly appreciate your help and I certainly don’t want to seem rude. But you aren’t helping that much by saying “this is difficult” and “you are stuck”.
I thought this forum also helps newbies in search for infi, if not, feel free to correct me and re-direct me to an appropriate platform/forum.
Thanx Leaon.
The problem is that this isn’t just a matter of buying a few components and wiring them together and suddenly when you push a button it sends the GPS coordinates to whereever it is you want them sent.
You’re going to need to write some code that will run on the microcontroller to make it wake up when the button is being pushed, then start the GPS unit, wait until it gets a satellite fix (which will take as long as a minute or so), then read the data from the GPS, then send whatever needs to be sent to the call phone module to send the IM with the data.
Just giving you a shopping list of components doesn’t come at all close to solving your problem.
The fact that you don’t understand this means that this is probably too advanced of a project for you at this time, and no one wants to offer to teach you all of the basics that you will need to learn before you are ready for it. We are happy to help newbies, but no one is going to design your project for you from scratch, which is basically what you’re asking for.
You’ll need to understand how they would work together, you need to learn to design a circuit board, you need to learn how to program a MCU, you need to learn the details of how the MCU needs to communicate with the GPS & GSM modules.
Frankly, if you need to have this done by the end of April, you’d better clear your calendar and be prepared to do a lot of learning between now and then. Sparkfun has some tutorials on embedded electronics, that would be a good place to start. Lesson one is at http://www.sparkfun.com/commerce/presen … owerSupply
I’m sorry of this sounds harsh, but someone has to say it.
Keith
Khearn,
you aren’t harsh at all, this actually helps me to move foreward.
As mentioned above, we have someone who is an expert in Python Programming. the only thing he needs is the necessary hardware to begin with.
By your explanation the needed hardware is:
Microcontroller
Button
Telit GM unit
I’ll read the tutorials, thanx for your help!
