Where to Start w/Arms
Is there an IDE you guys recommend is the easiest to work with to use with winarm? I’ve seen something about Keil could be a choice.
How do you setup winarm? I just see a bunch of folders with misc. files; I was hoping this would be as easy as setting up winavr and avrstudio.
Yes it should be just like winavr.
You need the zip, I got the 20060606 pkg.
http://www.siwawi.arubi.uni-kl.de/avr_p … 060606.zip
Readme.htm:
Installation
Unpack the archive to C:\ (i.e. C:\WinARM\bin should exist) and extend the system search-path (environment-variable PATH) by C:\WinARM\bin;C:\WinARM\utils\bin; Other locations/drives have not been tested but should work too.
