Rowley has a very nice debugger/simulator. It’s worth the money for that alone.
Leon
Leon
Thanks for the suggestions.
I used the Borland command line interface years ago and have gotten spoiled with IDE’s and good debuggers/simulators. Hard to go back.
The CrossWorks looks good and the personal license is a very reasonable price. The CrossConnect JTAG is a bit pricey however.
The Olimex JTAG sold by SparkFun seems to be a Parallel port interface. Any suggestions on a inexpensive USB or Serial JTAG interface that works with CrossWorks for programming and debugging? Or could I just debug in the simulator (like I do with the PICs MPLAB) and program with a serial connection?
Amontec makes a low-cost USB JTAG that works with CrossWorks. I bought one (for a different chip) and checked that it worked with an ARM, but I usually use the CrossConnect.
Leon
waltr:
They also have a USB JTAG.
http://www.sparkfun.com/commerce/produc … ts_id=8278
I use the USB OCD Tiny with Crossworks Studio. Works well.
Yes you are right. I personnaly started with 8051 (8-bit uC)Hi!
I guess that alot of you started out with the PIC or AVR and moved on to the ARM, am i right? What made you move to another platform?
It depends on the application/end product it self. RTOS have a lot of advantages for big projects, since it is easier in terms of expandability&modularity. On the other hand working with a simple super loop is more reliable and many companies use it for their products.Do i need an operating system with the arm if its going to be useful to me?
Yes it is.Is it as easy to run motors with this chip as with the PIC/AVR?
Definitely here you need a fast processor than pic/avr. ARM will do the job. But you might need some DSPs. it depends on the application.Is the ARM for me if my aim is on video processing/streaming? Or will the PIC and the AVR do the trick?
Best thing is try to understand both architectures and you will be ablae to reply to this question.Im familiar with intels x86 processors. Would i be better of with a x86 board instead of a board with a ARM on it? Why/why not?
the x86 is for different kind of applications. for embedded development i recommend ARM. check http://www.embeddedrelated.com/usenet/e … 3009-1.php
