I’m considering buying a WiFly, and before that I need to know if the Library for ARDUINO supports the following: I need to list the existing SSIDs in an area, and the signal strenghs WiFly is receiving from each one of those SSIDs. Can I do that using the Library?
Thank you.
-SR
SERGIO.R.F.OLIVEIRA:
The current version of the library does not support this but I am part-way through implementing parsing the output of the "scan" command which includes signal strength. It should be included in the next library release.
–Philip;
